Gen 3 ZX10R - Anyone had this happen before.....
greenmeanie
Post by greenmeanie »
......hit the starter & the tacho goes right around & back to 0(like it does when you initially turn ignition on) & in the process it cleared the time(clock) & reset the trip meter back to 0.
Bike was warm not cold start as i'd been riding for about 15 mins & pulled up to go into a shop. When i came out & hit the starter ^^^ happened.
Started the bike about half a dozen times this afternoon with no issue.
This has never happened to me before. :?
Anyone have any ideas ?
Glenn
2009 ZX10R
Re: Gen 3 ZX10R - Anyone had this happen before.....
Mine does that when the battery is getting low.
You also find it puts the shiftligh back to like 8grand
PeteZX12
Post by PeteZX12 »
Greenmeanie, have you followed thru with the factory recall for the dud regulator/rectifier? You may be starting to show symptoms.
greenmeanie
PeteZX12 wrote:Greenmeanie, have you followed thru with the factory recall for the dud regulator/rectifier? You may be starting to show symptoms.
Yep did the recall for the new reg/rec earlier this year. Fitted a new battery about 2 weeks ago & no drama since.
Glenn
2009 ZX10R
