Hi all,
Hoping someone can help.
Just installed a Power Commander PC III to the 05 ZX6R.
The bike has a Yoshi RS-5 slip on muffler and K&N air filter installed.
The problem is, I can only find a map for the Yoshi full system.
No map available for just the slip on muffler.
There are maps available for other slip on mufflers Akro ,Two Bros etc
Do I run the Yoshi full system map or perhaps use one of the other slip on maps.
Any help or suggestions would be great
Cheers.
Power Commander Question..Maps
- Maddog
- Cwidova
Re: Power Commander Question..Maps
i ran an akrapovic slip on map with the muzzys and it worked fine....
'06 ZX6R
'10 FE390
'10 FE390
- fireyrob
Like has been said run a slipon map. Download 2 or 3 and compare them. They are probably all similar
- Maddog
Thanks guys
My thoughts were to use the Akro map
Seems kinda weird they do the Yoshi full system but not the slip on
Will try a couple on the next outing and compare them on the bum dyno
Cheers.
Cheers.
- Mattjin
Go have it tuned properly.
Loading unknown maps is like walking through a minefield. Most of the maps are from US bikes and most of them have different tunes from factory.
- born green
Mattjin wrote:Go have it tuned properly.
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
- Maddog
Thanks guys.
I had every intention to get it custom mapped in the near future.
Was just hoping, I could drop a map in it to gain a bit for now.
If no good with the couple I'll try on the next day out I'll go back to stock
Just finishing a few other things on the bike first then its off to the dyno for a tune and remap...(when/if the cashflow permits)
