Motors done so hopefully wont be long now
The Start, GPZ1100B1 frame and bottom end, Bandit front end , XJR swingarm. 5.50 GSXR750 rear wheel
My mate Rick made the caliper hanger. and torque arm left over from his ttr600 motard, welding the repositioned shock mounts and machining the pivot down to fit. and heaps of other stuff.
part of the new shed
Worlds coolest clock '[:)]'
clean the cases up
paint em and chase the threads for heavy duty Cylinder and crank studs
Dial the cams in for hopefully some good mid to top end
Ready to Rock and or roll, 1166 Arias Pistons, mildly ported B2 head and Cams
After rego I hope to put on some carbon look twin headlights
and recess the rear stoplight in flush with an LED setup and mini blinkers. Lawson seat cover and carbon hugger as well
Solid engine mounts from the parts bin, hope the vibes aren't too bad on a road bike
I butchered a brake side rear set off (I think) 91 GSXR750 roller I bought off ebay just for the wheels and copied it for the gearshift side
Rick made the pegs and welded the ankle rest on
I don't know if anyone has done this B4 but to make some
engine mounts quick I just marked em out drilled the holes
sandwiched them between two pieces of pine on the line
used one of thse flap discs on the grinder then draw filed them
too easy
Every things apart now frames getting blasted then I'll paint it up
