I have replaced the rear tail light of my 08 ZX10 with an intergrated one.. looks fantastic and is very bright.. works well..
I have also removed the ugly indicators that are hanging off the mirror stalks.. as well as replacing the mirrors for a set of 09 ZX6 mirrors.. much more streamlined.. and I have relocated my indicators to the parkers position..
I did grab a couple of 5 watt replacement push in blade type Amber bulbs.. and they work.. but are too weak.. also the flash rate has changed.. too fast now.. !!
I was advised to go to a newer style LED amber globe for the front which is supposed to be much brighter than the standard globe.. I still will need to change the relay so the flash rate is normal.. but has anyone done this..??
I assume the LED's are brighter..?? anyone got any info on these bulbs.. or has done a similar mod..??
Macca
