06 ZX10R lap timer not working?
My lap timer on the bike OEM isn't working. Anyone had this problem?
Wags
Wags
Wags
Bikes
ZX10R 06 Road
ZX10R 04 Track
Keep the Rubber side down under!
Bikes
ZX10R 06 Road
ZX10R 04 Track
Re: 06 ZX10R lap timer not working?
one of the buttons might be rooted.
does it start and stop but not lap? or does it not start at all?
- Cwidova
my 06 zx6r doesnt count the laps but the timer works......pulled the thing apart but couldn't see anything!!! maybe a common thing?Wattie wrote:one of the buttons might be rooted.
'06 ZX6R
'10 FE390
'10 FE390
so your lap button is rooted?
- Cwidova
yeah it is more than likely, just thought with waggy01 asking it might have been something that happens a bit....too lazy to fix it anyway and not that important
'06 ZX6R
'10 FE390
'10 FE390
- fireyrob
my 06 zx10 lap timer wont start. it was working then when we replaced the MC with a Brembo it hasnt since...
Ok I'll but a ohm meter on it and test it, thought I'll ask the question first. I sprayed some magic spray (CRC)in it and no go. The dash stays on the 0000000 and the button does jack shit.
Cheers for the reply
Wags
Bikes
ZX10R 06 Road
ZX10R 04 Track
Bikes
ZX10R 06 Road
ZX10R 04 Track
so your start button on the right side switchblock doesnt start it?
maybe its dead.
Firey, is yours plugged in?
maybe its dead.
- MadKaw
- Administrator
Don't go getting all "technical" on him...Wattie wrote: Firey, is yours plugged in?
- Tinman
MadKaw wrote:Don't go getting all "technical" on him...Wattie wrote: Firey, is yours plugged in?
You don't get correct timing on those things anyway
Live 2 Ride!
Honda 2003 Race bike
2009 Mozzie Green ofcourse
http://www.rcutopia.com.au
Could try checking the fuses under the seat. From memory it is the horn fuse that the lap timer runs off. i removed it for a track day and couldnt figure out why the lap timer didnt work. Put it back in, problem solved.
- fireyrob
There are wires hanging everywhereMadKaw wrote:Don't go getting all "technical" on him...Wattie wrote: Firey, is yours plugged in?
- JetPilot
Dont you have to be at a track for it to work....
Kawasaki Z1000r 2012
- fireyrob
There's a couple of blocks around homeJetPilot wrote:Dont you have to be at a track for it to work....![]()
ALL GOOD! IF all else fails read the manual. DOH!!!
Wags
Bikes
ZX10R 06 Road
ZX10R 04 Track
Bikes
ZX10R 06 Road
ZX10R 04 Track
