Advice Needed from the ZX7R guru's ....
Can anyone who knows there way around a ZX7R help with this *odd* issue ??
One of the boys on CanberraRIDERS has a very weird problem on his ZX7R.....
In the #2 plughole, there seems to be some sort of solid wire that looks like it 'appears' from inside the plughole (above the top of the plug) - winds its way around the plughole for a couple of turns, and then it ends, pointing straight 'up' the plughole...
Old mate has given the wire a bit of a nudge with some needle-nose pliers, but it seems pretty well lodged in there....
Normally, I would suggest that it was a helicoil repair that had gone wrong - but in this case, its 'way' above the level of the plughole to be a helicoil ( at least for the plug..) - the wire is solid, not copper-wire type stuff - it almost looks like a fine-grade oxy-welding wire to me ?? :? :?
Do these bikes have any sort of sensor which is located in the #2 plug hole ?? I'll grab a photo and bung it up here shortly - any help would be much appreciated - old mate doesn't want to stuff anything up by just reefing it out, and this wire is lodged good and tight ??
Re: Advice Needed from the ZX7R guru's ....
a dodgybros diy helicoil effort?
I doubt it's factory Gos. My memory isn't that flash, but all the same I don;t recall any foreign objects being in the plug holes of 7R's! 8) I reckon yr on the money with a helicoil repair botched!!!!
zx793rr
Post by zx793rr »
I've got the 96' road version, nothing there and the WSBK version with all the 2D data telemetry and nothing there.
Nothing like that on the 89' model either.
sorry mate
Try making it before you buy it.
aggerz
Post by aggerz »
Just had the top half of mine off doing valve adjustments and other fun stuff .. there was nothing in there like that.. +1 bad helicoil job.
Current - 76 Z900 - 01 ZR7
Past - 92 KDX200 - 96 ZX7R - 93 ZZR250
Lone Wolf
Post by Lone Wolf »
Nothing like that in mine :?
nescius
Post by nescius »
Thanks for posting this up Gos, it's still a bit of a mystery though :shock: We're going to stick a new air filter in it this weekend so I'll have another squiz at it at the same time, i'll also try to get a decent photo and give it a good poke to see if I can really figure out what it is. I don't think it has anything to do with the plug, looks like something that has been pushed through the wall of the plug hole (don't ask me how) and there is nothing like it in any of the other plug holes. I'll let you know if I figure it out :D
No worries mate - good luck with fixing this one - of its still giving you grief I can have a look next week (back on holidays then till the end of January YAY !!! :kuda: )
thanks everyone for your help - its a fairly odd sort of thing to find lodged tight inside your plughole !!! :lol:
mfzx6r
Post by mfzx6r »
A hellicoil fitted or gone badly I'd say mate.... Maybe even a hellicoil that was too long for the job.
Mario
'01 zx6r
klx300r
Part of the "Fookarwe" tribe
the kid
Post by the kid »
mfzx6r wrote:A hellicoil fitted or gone badly I'd say mate.... Maybe even a hellicoil that was too long for the job.
Fuck me ! :shock: Marz being serious . Well I never :lol:
