Bike is smoking. Needs help Quiting
Hey Guys. Hoping you can have a few guesses whey my 1995 zxr750 is smoking. I ll give the full story.
I started my bike up as usual to go ride to work. Let it idle and warm up while I get my gear on.
I rode around 1 km away from home stoped at a set of lights and the bike is smoking like a Mofo. Grey Smoke from the Exhasut. Bike doesn't seem to have lost any power or anything.
It starts first kick without any issues and it doesn't start to smoke until 3 to 4 minutes while idling.
THe longer the bike runs the more it smokes.
1st thing I thought was the Crank case breither was blocked or somthing. I checked that and it seems fine. I can start the bike up while the 1 way valve is off and just venting to tha atmosphere. I can feel a very slight amount of air coming from the hose.
How much blow by \ PResure should I be getting?
Haven't checked the spark plugs to see if there is any Black oily plugs.
Few things I think I have rulled out
- I would have thought if the valve stem seals were shot it would smoke heaps on start up,
- If the oil rings were shot I would think it would smoke straight away
- If the compresion Rings were warn I should have been getting alot more blow by than what I was getting.
- There is no WAter in the oil and there is no Oil in the water so im guessing the head gasket is fine
Any ideas guys?? The bike has 75000kms
- Rossi
Sounds like a head gasket to me mate cos
white smoke generally indicates water getting into the block BUT
with the cold weather we have been having it could just be condensation thats collectedin the exhaust pipes .....there should be a small drain hole in the pipe/collector box area, check that's clear first
If it gets smokier as it warms up it sounds like oil leaking into one of the pots from the head alright, because as the oil get hotter, and thinner, more will get pushed/sucked through. Or depending on ya model, from the rocker cover where it mates with the spark plug holes but that would only be a little oil weeping past the plug. Doubt if it's an oil ring cracked because that would cause smoke to piss out right from go. Sounds like a head issue alright, Take the rocker cover off and check the tension on the bolts, you may get lucky
