Chain Tension on GPX250
I know this topic has been discussed before but I can't find the tread so here goes again.
My GPX250's chain touches the centre stand when stationery. I'm guessing that this means that the tension on the chain is too loose (although there's no obvious scrape marks on the centre stand at the moment).
Can anyone educate me if this is the case.
- Lainie
- Team Ninja
- Bike: ER6
This is the link for the manual if it's any help to you
http://home.swiftdsl.com.au/~tenoq/GPX250Manual.pdf
Thanks for all the posts.
The slack on the chain is a lot more than the recommeded limits so I decided to take it to the bike shop today to get a professional opinion. The verdict, I'll need a new chain & sprockets on the bike as these are parts that need to be changed every 25-30,000kms (or so I'm told). Apparantly it's not worth adjusting the tension as the chain stretches through it's lifetime and this one is close to its limit. The damage for this will be $260 (and another $170 for a new Bridgestone rear tyre 'cause the current one is in bad nick). Better start breaking the piggy bank.
I had the same problem, I had a bad tight spot in my old chain and was hitting the the kick stand I do recomend get 2 new spockets and new chain. Also recomend put a 47 tooth spocket on the back. Ive just done that and makes a heap of difference in exaleration. But will rev slightly higher at a 100ks.
I might give that a try because acceleration is crap at the moment (get beaten off the lights by Hyundai's & Kia's) although I suspect it has more to do with the chain in it's current state than the sprocket size.
The price I was given at the bike shop was for the "standard kit". Do you know how much extra it is to put a 47 tooth sprocket in place of the standard?
- kellz
must be teh week for gpx chain and sprocket issues.
well after coming down mac pass adn hearing a not so nice clunking on down shifting, time to tighten chain was way to loose, and also found wheel alighnment was out, so i did that and also chain guard was hitting chain as it had warped, dont know how, so that explained the annoying clunk coming down mac pass
its quiet easy to do yourself kc, if i can do it you can.
a bit of string for teh wheel alignment, about 3 spanners and a race/ centre stand and your right
