zx7r spark plug question
raffiki
Post by raffiki »
sup kids
i got my 7 in the shop being fitted with an akro evo titanium and ivans jet kit YUM :D
i've held off on the ignition advancer cause the guys said it could be more trouble than its worth on pump fuel + they arent a street bike performance shop with a dyno so they said take it to balls and they can make a mess of it, while its there i'll get them to put in the ram air tubes i got too ;)
but to my question what sort of spark plugs should i get? some people say get these others say plugs are plugs... boo so confusing :x
insert brain > here <
HemiDuty
Post by HemiDuty »
I think the standard CR9E plugs will be fine man, and cheaper too. The iridium I think just lasts longer more than anything else, and the split fire type ones (CR9EX I think) might make a bit of a difference but I think they all have to be indexed to face the intake charge for full effect. There is also these new plugs available called brisk plugs, I want to give them a go on the race bike, but unfortunately for you they don't seem to work on all 7Rs????
http://cgi.ebay.com.au/BRISK-High-Perfo ... dZViewItem
HTH.
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
ColourSmart Chroming
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
I-K
Re: zx7r spark plug question
Post by I-K »
raffiki wrote:some people say get these others say plugs are plugs...
The second lot would be right...
Johnnie5
Post by Johnnie5 »
standard plugs at about $3 a pop are the way to go
can afford to change em more often and have nice new plugs again
jpbikeboy
Post by jpbikeboy »
NGK CR9EK. There are the split fire plugs. They do give an increase in power on the 7's. Someone dyno'd the difference and it was a couple of horsies i think. have a look at this link.
http://homepage.ntlworld.com/webzxr/zxr750r/
We Be Toyz
Post by We Be Toyz »
jpbikeboy wrote:NGK CR9EK. There are the split fire plugs. They do give an increase in power on the 7's. Someone dyno'd the difference and it was a couple of horsies i think.
Yep - running the same on my 7.
greenmeanie
Post by greenmeanie »
Got Denso plugs in mine.
Glenn
2009 ZX10R
nothing wrong with normal spark plugs. they do the trick
