gpz 900r pods?
All GPx and GPz Models
91ninja9
gpz 900r pods?
Post by 91ninja9 »
gpz900r 91 model, would the carbs need retuning if i fitted 4 x single pod filters?
Lucas
Post by Lucas »
yep they sure would
Lucas
Black ZX10R 05
1958 Vespa 150
1928 A Model Tourer
Johnnie5
Post by Johnnie5 »
they sure will and honestly its not worth the probs
you will lose bottom end performance
If you are racing and want to tune for topend then go for it but if you ride in the street and want a bike that performs smooth through the rev range and has reasonable fuel economy then keep the airbox
the airbox is designed the way it is for a reason
bonester
Post by bonester »
years ago I removed the restrictor in the airbox of my GPZ900- the service manual showed earlier models without it. Bolted it back together and tried to ride it to work the next day- ran fine until 3000rpm, then died in the arse- terrible trip into and from work- put it back in that night- I can imagine that pods would do massively terrible things to the carburation. :oops: :shock: :?
91ninja9
Post by 91ninja9 »
thanks for the advise, have bought a uni-filter replacement. :shock:
