Lining up the back wheel correctly
thewonderer
Post by thewonderer »
Guys,
I heard somewhere that you can't really trust the marks on the swing arm to truly line up the back wheel when you make adjustments to the chain or swap over the tyre.
I heard that the swingarms have a margin of error in them. The best way i've heard is to use some string fron the front of the bike to the back axle or something like that.
Does anyone have the definite guide to keeping your front and rear truly alligned correctly?
Martin
ty
Bike: Honda
Post by ty »
I've always used the marks - in my opinion the string method is more error prone.
Unless your frame is bent the swingarms marks should be sufficient.
Other than that a straight edge rather than string would be the way to go.
ty
javaman
Bike: GPz900
Post by javaman »
Quite a good article here on how to do that:
http://motorcyclistonline.com/howto/string_align_motorcycle_wheels/
But I just use the marks, should be allright ...
-ariel circa 2007
http://GPZninja.blogspot.com/
you either need a frame jig...like the race teams use
to check the alignment of wheels to each other
(and the frame)
or just use the swingarm marks.
The only time I have ever found the marks to be out
is when the swingarm bearings were stuffed and the swing arm
was slopping all over the place (on a Suzi waterbottle I had)
hth
Rossi
Post by Rossi »
Use a small laser pointer/level, put it on the rear cog and align the laser along the run of the chain :wink:
There is some kinda laser gadget on the market that fits to front sprocket and rear sprocket, can't recall price just now - but it wasn't as cheap as string
i just use the marks, should be cool :wink:
Tones
Post by Tones »
The good 'ol string method is a tried and trusted method. Problem with it however is doing it right. That means yorus tyres must be true. If the string is caught in part of the tread, or the tyre is a little out then the string will also be out. You need a centre or race stand to do it and then it is good to have two people to ensure steering is straight etc. The other thing that can catch you out is where the string is run. Sometimes it can foul stands, exhaust, etc. I often use this method to "check" on the accuracy of the marks, then use them thereafter. If a chain adjustment is needed I just ensure that both adjusted are turned exactly teh same amount. I would also add that be careful when tightening up the axel. Make sure you are tightening against the adjuster so that it "sets" the axel position. I have seen some people caught out when they tighten the axel it creeps away from the adjuster and therefore throws the wheel alignment off. Of course we all know that Both adjusters on each side are required to be used for adjusting a chain. Sorry have to say it just in case.
Another method is to have someone ride towards you and look at the front wheel and check that the rear wheel tracks evenly behind it. If the rear crabs to one side it will most likely be due to the rear being out of adjustment. If a biks is crabbing it will usually be pretty obvious. Traveling towards you at about 25 km/h on a flat road should do it.
Usually the marks can be pretty accurate (provided the frame is straight etc. You would be surprised to see how many are not from the factory). Often the techniques for adjusting are more so the cause. Some people may be able to pick if a bike is crabbing as it will turn easier one direction than the other, but some dismiss it due to having a preverence to one over the other as well.
mate use the markers on the swing frame and then double check the distance with a steel ruler or a set of calipers.
ross79
Post by ross79 »
Rossi wrote:Use a small laser pointer/level, put it on the rear cog and align the laser along the run of the chain :wink:
I came across that while flicking through one of my magazines. It's called
a Profi C.A.T. laser. Costs $99 can be found at http://www.ausit.com.au
or call them on (03) 9602 4400
SOLD 2000 ZX12R .
chameleon
Post by chameleon »
just get ya self a zzr11, you only have to do it once cause the two sides move in unison as you spin the locked eccentrics.
chameleon wrote:just get ya self a zzr11, you only have to do it once cause the two sides move in unison as you spin the locked eccentrics.
thats cheating :wink:
Post by mick_dundee »
No that's clever, even easier method is just buy a shaftie :D
Tones
Post by Tones »
I second that!!! hehe
doesnt ur boyfriend give u the shaftie for free
