Oil Leak from Clutch slave cylinder (95 zxr750)
Ive got a bit of a Dribbler oil leak here. And by looking at the Manual and on the microfiche im unable to see any seals what so ever.
I took the clutch slave cylinder off and the area infront of the piston had 40ish mls of oil . Also I noticed there wasn't any gasket or sealent of anysort on the faces of the slave cylinder and engine casing. is this right??
If anyone can give me any ideas why oil is leaking out of here especially when the oil presure builds up at higher revs and when im riding the bike. Letting it site on the stand and free reving it doesn't cause the oil to squirt out.
EDIT: AND yes it is oil. As I had close call as even riding 20 kms it was enough to cover the fairing and dribble infront of the back tyre
- greenman43
There is a seal for the clutch pushrod, that sits in the transmission cover (the cover behind the front sprocket) ; on an L you need to remove the cover, and replace the seal from the inside.
The part you're looking for is 92049-1017 ; you can see it as part 92049 on the Engine Covers page of the buykawasaki.com fiche for this model.
Brian
Brian
- greenman43
No worries mate, it's an easy job, just a bit messy. Sing out if you need any guidance.
Also, have a close look at the pushrod, and make sure there's no marks or burrs on it which would damage the seal ; obviously, it should be smooth to the touch.
Brian
Brian
Ordered the bits this arvo
I see what you mean by Messy...
Nice and easy until I took off the front sproket cover.. Amazing what you pick up with a heap of sticky chainlube.. 2 nuts and a washer that is not mine and not from the bike!!
Damn water pump was stopping 2 bolts as well. So off they went.. aahhhhh Oil..
put pump back in. Get oil pan. drain oil
Now I have to buy a big assed socket to get the front sproket off.
- greenman43
You should also use an impact driver to undo the phillips-head screws holding the cover on ; chances are they'll get wrecked just using a screwdriver.
Also, remember you'll need a gasket for the cover.
Brian
Brian
I orderded the Cover gasket, Clutch pushrod seal and while Iwas at it Front sproket spline seal thing..
Ive got my trusty impact screw driver ready!. I actually didn't even see the phillips head screws there until I removed around 1cm thick Chain lube, Dirt, 2 nyloc nuts encased to chainlube and a washer!!
Re: Oil Leak from Clutch slave cylinder (95 zxr750)
Is it possible to remove the transmission cover with the engine still in the bike?
1993 ZXR750 Track Bike
1994 ZXR750 Ongoing project
- Kwakked Up
Did one recently on my zx7, easy job. From what i can tell on yours it is done with motor in.
06 zx10r - road
99 zx7r - trackie
77 z1000 - project
99 zx7r - trackie
77 z1000 - project
