Rear Brakes
Rear Brakes
Has anyone here fitted rear brakes before? Or does anyone know how hard it is to do??
I'm hitting the track on Sunday and would like some extra brakes incase......
Thanks guys
Dave (the rider formally known as Chris)
Thanks guys
- Smitty
Re: Rear Brakes
budgie wrote:Has anyone here fitted rear brakes before? Or does anyone know how hard it is to do??
Thanks guys
huh..?
don't ALL kwakas come with rear brakes
- Smitty
budgie wrote:Ill rephrase it a little.
My rear pads are almost gone, does anybody know how hard they are to replace or should i just go to a workshop and have them done?
ummm
mate, the fact you are asking this means I would recommend
you don't do this yourself...get a pro to do it!
imo, brakes are one thing not to play with.
- ty
- Team Ninja
- Bike: Honda
It's pretty easy - but your local mech will probably only charge you $10-20 to do it for you.
Basically:
1. unbolt the caliper from the swingarm - (likely need an allen key)
2. with the old pads still in the caliper, use a flat-head screwdriver or similar between the pads to force the pistons back as far as they'll go.
3. Take out the holding pin on the back of the caliper - should be a small R-clip holding it in.
4. Take out old pads.
5. Insert new pads.
6. re-insert holding pin and R-clip.
7. slide caliper back over disc with disc BETWEEN the pads
8. bolt up allen key bolts.
9. pump rear-brake until the pads bite.
hth
ty
Basically:
5. Insert new pads.
hth
ty
- Smitty
ty wrote:It's pretty easy - but your local mech will probably only charge you $10-20 to do it for you.
Basically:
5. Insert new pads.
hth
ty
ty
what bike's this for...???
never done a rear caliper with pins or an R clip on it
and no anti squeal shim???
