Just tightened the chain I put on a few months back for the first time, it seems to have stretched very very slightly as it was slightly looser than recommended. I'm guessing this is relatively normal, is this correct?
Didn't need much in the way of tightening, but it was a learning experience and I needed to buy a 27mm socket. I seem to have it all back together properly, I suppose I'll find out for certain tomorrow on the way to the station
Hopefully do an oil change this weekend, planning on using Motul 5100 again, is this still recommended as a 'good oil'? I've got the filter removal socket this time, so it shouldn't be as traumatic as last time.
I noticed the inspection window has 'fogged' over with something creamy-looking, I'm guessing an oil/condensation emulsion, is this normal for winter? I can't see how much oil is/isn't in there atm, which is a pain.
Thanks all
