Fuel and ignition questions for zxr250
Hi All,
I have a 1989 zxr250a and have a couple of questions about fueling and ignition timing for this bike.
1. Does anyone know what RON fuel Japan was using in 1989? Did a bit of a web search and it appears it was probably high 98-100 like it is now.
2. When the zxr250 was complianced for Australia, did they change the ignition timing to account for 91 octane fuel here?
3. If so, is it possible to adjust ignition timing on these bikes? I assume they must have a crank or cam angle sensor of some sort somewhere but can find no reference to timing adjustment in the manual.
FWIW I have tried running the bike on 91, 95 and 98 and can't really notice much difference so am using unleaded 95 at the moment as a middle ground to be on the safe side regarding pinging.
NinjaBaby
NinjaBaby
SocialSecurity
- State: Western Australia
98-100 RON fuel would have been the bees knees in japan in 1989 (like it is now) and only turbocharged vehicles would have required it
AFAIK, the japs have a 91 octane fuel too.
you will get best results with regular 91 RON unleaded, its what the bikes are designed for, JDM or aussie spec... premium will typically make the bike run a little rich, or harder to start in the morning unless you rejet to suit (no point)
only way to change ignition timing would be to get a different timing rotor, or fiddle with the CDI - dont think anybody would make timing retarders for an old 250, and i wouldnt touch the CDI. you dont need to take timing out
SocialSecurity
SocialSecurity
SocialSecurity
- Nanna10r
- Team Ninja
I'd go 98, i heard the japs dont have 91 ron. Its a cheap way to get longevity outta any motor imho.
cheers Brett
cheers Brett
SocialSecurity
