Brake pads
HemiDuty
Brake pads
Post by HemiDuty »
Can you get good pads for the front of a GPX600R? I wanted to get Goodridge RGH or similar, but cannot find a model listing anywhere on any of the main sites. Powercycle said they had some Ferodo sintered things when I rang them, but I am unsure how good they would be. If I have to spend money I may as well get good pads.
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
ColourSmart Chroming
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
ZX10R King
Post by ZX10R King »
Phone Mick, or Two Wheel Tyres
SXC in black, '05 ZX10R
Hemi I just had a scan through the EBC site, and the GPX wasn't listed :?
I bet they will be listed as a 'compatible' pad for another model, Kawasaki do this quite a bit with calipers used between different models etc.
What year model GPX ??
have u tried SBS, i think its called scandinavian brake systems.
http://www.sbs.dk
They are distributed down under.
TBone
Post by TBone »
I think I can get OEM replacement (ie. aftermarket) pads... $25 a set..
you will need two sets for your bike as it is twin disk front... so $50 + postage which I think is around $8
HemiDuty
Post by HemiDuty »
Wow that is cheap Tbone. I do not suppose you can get any sportier pads? Anyway, I haven't priced OEM reps yet, but that does sound cheap when compared to the only aftermarket ones I can find ATM (till everyone opens up after Xmas anyway) are like $49 each, and they are Ferodo. I do not expect Ferodo to be anywhere near as good as the EBC/SBS or Goodridge pads.
So, can you get anything else, or just the one model, and can I ask what brand they are? (not that it matters much with OEM type pads I guess.) And also how quick can you ship them off?
Drim.
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
TBone
Post by TBone »
I can get pads for %99 of bikes sold here in Australia and some gray imports...
I have some pads in stock but... When I put in an order I have the pads within 48 hours and if I'm posting them out I do it theasme day I recive them... so If you pay for express post you can have them next day!!
I'm working on a good and realiable supply of sintered pads as well so soon I hope I will have them in stock...
All OEM replacement pads are about thesame... defenately better than the OEM so it does not metter who is the manufacturer... Ferodo, EBC, SBS and Goodridge all have to comply to minimum standards... The ones I can get are MetalGear and they are THE pads that %90 of Australian bike shops use when you get your bike serviced and don't ask specificaly for a brand name pads to be used...
HemiDuty
Post by HemiDuty »
So how long do you think it will be till you know if you can get sintered pads? It's just that I really want to put something a little softer into it, so it stops harder at the track etc. and also so it looks after the already borderline discs a bit more.
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
TBone
Post by TBone »
HemiDuty wrote:So how long do you think it will be till you know if you can get sintered pads? It's just that I really want to put something a little softer into it, so it stops harder at the track etc. and also so it looks after the already borderline discs a bit more.
I do belive Sintered will chew up your disks quicker than the "green" or organic pads... simply as they are desidned to be used on Steel disks and not stainless steel... if you want more stoping power change over to racing disks (also known as Full floating) and make sure they are made out of steel...
I have been informed that Sintered pads will be avalable for some Kawasaki models in January/Feburary...
Re: Brake pads
HemiDuty wrote:Can you get good pads for the front of a GPX600R? I wanted to get Goodridge RGH or similar, but cannot find a model listing anywhere on any of the main sites. Powercycle said they had some Ferodo sintered things when I rang them, but I am unsure how good they would be. If I have to spend money I may as well get good pads.
am guessing but aren't the pads the same as the GPx7fidy..???
I have been using SBS or EBC (good for road and track!)
and have to report...
am up for another set on the front on mine!
wore them out today doing Mt Donna Buang and part of Reefton today :P
will quiz BKwaka in the morning...and let you know!
TBone
Re: Brake pads
Post by TBone »
Smitty wrote:am guessing but aren't the pads the same as the GPx7fidy..???
yep they are same according to my catalog...
HemiDuty
Post by HemiDuty »
So the sintered jobbies will definitely wear the discs quicker than the normal pads you stock then?
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
TBone
Post by TBone »
HemiDuty wrote:So the sintered jobbies will definitely wear the discs quicker than the normal pads you stock then?
That is what I have been told... I also read once some general info on maching the disk materials to the pad materials... from memory least wear you get is form OEM pads (and OEM replacements which are metal based) used on OEM Disks... it is when you start changing compounds of the pads and disks (basicaly miss meching) you get exesive wear... of eather the disk or the pad...
I'll try and dig out the info...
no quite sure
but SBS Brakes state this on their site..... (http://www.sbs.dk)
NEVER use sintered brake pads in calipers originally equipped with NON SINTERED brake pads. :shock:
TBone
Post by TBone »
no quite sure
in that case there are a very fiew bikes (and as far as i know most of them Kawasaki) that can use sintered pads....
