Crack in engine cover
Hi i just found a tiny tiny pin hole in my engine cover (left side) on my ZX2r what i was wondering is can i just put a spot of weld on it to stop the oil coming out or should i get a new cover?
Dont tell me the sky is the limit when there are footprints on the moon
If by pin hole you mean something small then you could try one of the epoxy based metal repair/fillers.
Tons around but get a high temp one... eg. http://www.alvinproducts.com/
Used em for trackside engine cover repairs in the dirt before and work a treat. Cant recall the actual one though.
- Bike: Z900
- State: ACT
What you need is a small amount of Devcon. Its an aluminium-based epoxy resin that is heat-resistant up to about 200deg from memory
. It is the best stuff on God's Green Earth for fixing stuff like that.
I regularly used to use it when repairing base gasket surfaces on single-cylinder 2-strokes........you know, old mate chooky legend fixes his own bike......" Lever the bastard cylinder off with a big screwdriver............Woops, look at that butchered gasket surface...." just apply Devcon, when it sets it can be machined/filed flat.......
In an emergency, if you can't find any Devcon ( the real McCoy), then those 'Metal-repair' tube-kits from SuperCheap'N'Nasty will do the bizz.
- photomike666
Stick a bit of chewing gum in it and rev the farker hard. The heat will solidify the gum and it'll be harder than the original cover. I'd recommend spearmint, but juicy fruit will also be just fine
*edit* Gum has to be chewed before application, dry gumn will simply fall off
