I have bought a few things from this guy and it has all been good stuff.
Thought i'd better give him a wrap
Get on and check it out, there some good stuff for all bikes in there.
dont tease mediesel wrote:what are you cooking up now coco?
get ur hands on an RSV did ya??
sounds good, that'll take care of the brake and clutch lines. do they use the existing fittings and give you new rubber or go the hack and make a whole new line, fittings and all? and how much did it set mira back? if it fairly hefty i might be better off just going the braided lines that i want to eventually have anywaysSocialSecurity wrote:if you need longer lines just go to your local enzed, pirtek or ABS shop ... take them the existing brake line, and tell them how much longer you want it... a few bucks later you'll have what you want
yeah, they do 6" over braided lines. $160 front and $80 clutch for a memory, but i cant confirm that cos the site dont workSocialSecurity wrote:they usually just look at the type of banjo fittings on the standard lines, making sure the angles are all fine and use brand new ones
i think to get a ~400mm line with banjos on both ends was about $40
they can make them braided aswell, give them a call. do austreetfighters sell longer than stock items?
i guess if they are cheap and fit perfectly then they would be the go-er... but that may not be the case, and they are up in QLD i think... where u could just get one made up at lunch time
is the 7R clutch hydraulic?
