Standard 7R Sprocket sizes?
- HemiDuty
- Bike: Don't have one
Does anyone know the standard number of teeth on the 96 7R sprockets? The one on the back ATM has 43 teeth, but I do not know if this is the standard gearing. I only get to the top of 5th at QR so could afford to use lower gearing, and when I can afford it I want to go to a 520 pitch chain.
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
ColourSmart Chroming
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
DC Racing
Extreme Motorsports
M2R
Castrol
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
- Smitty
ummm
had a look in the service manual
its not listed for yours
the manual for the J and K models shows 45 teeth as standard on the rear
so I rang my friendly dealer..they said 43T is standard on yours
and I went to Buykawasaki.com..it also sez 43T is standard
so I guess 43 it is
hth
so I guess 43 it is
hth
greenmeanie
- HemiDuty
How much difference to speed and acceleration has it made?
Basically I want to gear it down to the point that top gear has the same final ratio as 5th does now. So that I can get it cranked in top at QR, as that is the biggest straight the 7 is ever likey to see.
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
DC Racing
Extreme Motorsports
M2R
Castrol
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
- MadKaw
- Administrator
I had 1 down on the front (close to 3 up on the rear) and that was enough to redline in 6th at Eastern Creek straight. I'd suggest you could probly go 1 down on the front and 1 or 2 up on the rear for QR as its not as long....
