just wondering how often i should replace fork oil on my zx7r?
i saw a good topic a while ago where smitty had a few good things to say but i must be a spastic because i cant seem to be able to find the friggin topic grrrr...
can anyone point me in the right direction?
how often to change fork oil
insert brain > here <
- Smitty
Re: how often to change fork oil
mate.....raffiki wrote:just wondering how often i should replace fork oil on my zx7r?
here ya go......'
http://69.90.170.150/~ksrcau/phpBB2/vie ... php?t=2750
oh
and I recommend every 10,000 or 2 years
(although after revisiting the post where I said 7500 or 18mths
and it came out black...maybe sooner)
hth
- Smitty
Mikemike-s wrote:Speakin of which Smitty, how much oil would you have put into each fork leg? i've been pondering doing my front forks for a long time & have been procrastinating quite well thus far.
I also need to see just how leaky my front forks are, i know theres at least a minor leak. . .
approx 350mml in total
but you do the change and add oil..not in volume but in height
huh?
when the old stuff is drained, you compress the forks and add oil
so the air gap (oil to top of fork) is
LEFT 120mm
RIGHT 150mm
make sense???
oh
and fix the seal when you do the change....
I would have said 20 000km but i will be changing some fork springs next week and the oil is only 7500km old and i will probably change it, but from previous experiance when i did the oil in my 250s forks it came out looking like diff oil that had done 350000km ...decidedly very second hand.
If your just doing damping rod forks every 10000km would be plenty and its only 20 bucks worth of oil your changing.
