ZXR750 and ZX7R
the kid
ZXR750 and ZX7R
Post by the kid »
Can some techo historian explain the differences between the ZXR750 and zx7r . And was there a factory turbo thrown in there as well ? Do like the look of these beasties but don't know the changes and relative merits of these bikes .
One other detail , do they run without the induction pipes and box in place , any way of changing that stuff around ?
Thinking project "Rat ZX7" Just thinking :idea:
mfzx6r
Post by mfzx6r »
There aint a lot of difference between the L1-3 , '93-95 and the the zx7r.
The zx7r was just the next Gen of the zxr750.
The zxr's had 1 air inlet,'93-on, and round lights .
They both have "USD" forks and Imo not alot different to ride.
No turbo on any stock zxr/zx7r.
pre '93 had no air ram as such
mario
Mario
'01 zx6r
klx300r
Part of the "Fookarwe" tribe
mfzx6r wrote:There aint a lot of difference between the L1-3 , '93-95 and the the zx7r.
mario
oooooh
history lesson (think we have dun this b4)
the GPx750r was the start of that family (F1 F2 and F3 models)
Kwaka took the GPx engine (and some other bits) into a new frame
and stuff and called it the ZXR750 (H1 started the series)
and that continued until they changed the engine (internals bore&stroke)
and it continued on as ZX7r
the rest of the details as per Marios post above
that just about covers the '750' lineage
the only other comment is that the bikes got heavier
on each model change..the last ZX7r is a bit portly
but a great handling sportsbike (better than its rivals at the time)
btw...
the last factory Turbo was a GPz750..from 'bout 1984
(I had one and it was a shocker :( )
hth
HemiDuty
Post by HemiDuty »
I was looking for a ZXR750 before I got my ZX7R. I like the 7R more, but I would be damn happy with a ZXR. As long as it is a 750 ya can't go wrong. But I would definitely aim for the USD forks.
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
ColourSmart Chroming
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
NovaCoder
Post by NovaCoder »
Smitty wrote:oooooh
btw...
hth
But wasn't the GPx750 also based on the GPZ750 which was itself a down-sleeved GPZ900 :?:
And wasn't the GPZ900 the first ever motorcycle?
:D
Race #87 - Blog
greenmeanie
Post by greenmeanie »
Glenn
2009 ZX10R
NovaCoder wrote: But wasn't the GPx750 also based on the GPZ750 which was itself a down-sleeved GPZ900 :?:
Nova
the GPz7fiddy was a shrunk 900 ( I say that from memory)
but
the GPx engine was all new
it is water cooled (and also had an engine oil cooler)
the Gpz engine is not (air cooled)
the Gpz specs are-
Displacement: 738 cc.
Bore X Stroke: 66 mm. X 54 mm.
Compression Ratio: 9.5:1
Max. output: 80 h.p. @ 9,500 rpm. (59.7 KW.)
Max. Torque: 48.5 ft-lbs.@7,500 rpm. (6.7 kg-m)
Carburetors: Mikuni BS34 (4 of)
the GPx is-
Displacement: 748 cc.
Bore X Stroke: 68 mm. X 51.5 mm.
Compression Ratio: 11.5:1
Max. output: 108 h.p. @ 11,500 rpm. (79 KW)
Max. Torque: 8.7 kg-m @ 8500rpm
Carburetors: semi-flat slide Keihin 34mm (4 of)
as you can see, a totally different engine
oh
and NO, the GPz900 was not the first bike :lol:
my '69 model MachIII was 8)
hth
the kid
Post by the kid »
Thanks Guys for the input . That 750 link is a beauty . Theres a lotta luv out there for the 7
But not as much as for the 9 . "Gotta love the 9" :twisted:
Smitty wrote:[ ( I say that from memory)
but
Actually :roll: Just to split hairs, there were two versions of the GPz 750r produced and sold here in OZ. The first was of course the air cooled model, then we also had a later water cooled GPz750. :wink:
Strika wrote:...
we did?
the original GPz I had was aircooled
and the turbo copped an oil cooler (still aircooled)
but I don't seem to remember a water cooled GPz750 engine
mind you that was 20 years ago
they did for sure. I seen, touched, ridden, worked on two or three :wink:
It was leter in the model run.
And FYI- ZXr750 L3 and ZX7R P1, are two entirely different bikes in almost every way. Frame, swingarm, forks, Linkage, shock, motor, gearbox, brakes, handling, ride are all worlds apart. :wink:
Strika wrote:they did for sure. I seen, touched, ridden, worked on two or three :wink:
and seeing as were being picky there were a couple of bore/stroke changes (as well as frames etc) from the H model to the 96 zx7r (zxr's were called zx7's in the us of a :roll: )
