Hi all, just wondering if anyone could give me some advice on getting these screws out without stripping them. I have put some CRC on them and have had a go at them with the impact screwdriver but can’t seem to budge them. The intake boots are shot and I need to replace them. Because the boots are there I can’t seem to get the CRC into them. Should I try to grind a bit of the boot away between the boot and the motor? Also the impact screwdriver is no good for the inner screws due to hitting on the frame (access).
Thanks in advance. Deano.
When you say "impact screwdriver" do you mean one of these or air/electric?
I have found these to be excellent with Phillips heads, and the "use a bigger hammer" mantra works with them!
BrettZZR wrote:When you say "impact screwdriver" do you mean one of these or air/electric?
Yep that’s what I’ve got Brett but I can’t get to the inner screws because the frame is in the way even with the air box removed.
Can you drill, grind or file the head off? The stud will then come out easily, and you can replace with SS capscrews...
Thanks Brett,
I’m thinking you may be onto something there. I reckon I could easily get the 4” inch grinder in there. Once the boots are off I could spend some time spaying with CRC and leave it for a bit before getting the vice grips on I suppose.
I did get the right side outer screw out using the impact screwdriver. Once it freed it was fine.
You should find that once the boot is off the stud is no longer under any tension/friction and will turn right out. Often when drilling a head off, before it actually comes off, when the 'meat' of the head is that thin the head deforms upwards, unloading it and then grabbing the head with pliers gets it out. If you have serious corrosion, you may need to do as you have described.
BrettZZR wrote:You should find that once the boot is off the stud is no longer under any tension/friction and will turn right out. Often when drilling a head off, before it actually comes off, when the 'meat' of the head is that thin the head deforms upwards, unloading it and then grabbing the head with pliers gets it out. If you have serious corrosion, you may need to do as you have described.
Give the screws a good belt with a punch then try screwdriver. If you cant get the impact drive in you can sometimes get it by belting the screwdriver and turning at sametime. Even better if you have a screwdriver witth steel shaft all the way through.
If you can get a grinder in there, then you can also try and grind a 'slot' into the heads of the screws. Then you may get greater grip by way of a normal screw driver rather than a phillips head. I used that trick on my race car.
Bart179 wrote:If you can get a grinder in there, then you can also try and grind a 'slot' into the heads of the screws. Then you may get greater grip by way of a normal screw driver rather than a phillips head. I used that trick on my race car.
