Hi All
chasing a rebuild kit or master cylinder unit to suit my 1984 GPZ750.
would anyone know of where I could locate one?
WTB rear brake master cylinder GPX750 1984
Re: WTB rear brake master cylinder GPX750 1984
I've been getting some pattern parts from http://www.wemoto.com.au/ who seem to have a good range of routine wear items. They won't have a master cylinder but are likely to have a front kit.
What they don't have in stock usually comes within a week or two from their mothership in the UK. At the checkout you can see what is in stock and what isn't so you can rearrange you order if necessary.
- Smitty
leep wrote:Hi All
Fleaby throws up quite a number.. here is one example
Brake Master Cylinder Rebuild Rear for 1988 Kawasaki GPX 750 R
http://www.ebay.com.au/itm/like/3020853 ... 107&chn=ps
Going by factory part numbers (as found in places like http://www.cmsnl.com/kawasaki-zx750a2-1 ... ml#results) it seems possible to buy an original piston assembly. Even a bare master cylinder can be found , for a price.
Aftermarket rear kits for a ZX750A2 might be trickier. Some of the ads on eBay can be a bit confusing, like this one for a rear kit for a "1982 GPZ 750 R1": http://www.ebay.com.au/itm/Brake-Master ... SwagdXR3Wl
Then there is this used assembly in the US, which may need kitting anyway: http://www.ebay.com.au/itm/1983-Kawasak ... SwJ7RYSDzJ
Thanks all for your help, much appreciated.
Ive had zero hits from the local wreckers so the search is on!
