Hi guys,
I have a leaky front brake reservoir - seems to be leaking through the join.
Anyone know what I can use instead - these seem to be extremely rare items - I've been looking for a while...
Been looking at these - maybe they can be made to fit somehow? Is the hose that goes to the master cylinder 5mm (3/16) or 6mm (1/4)? Assume this one takes the 6mm hose.
http://www.ebay.com.au/itm/Universal-Mo ... SwqfNXkGKS
Ian.
Z1R Front brake reservoir
Re: Z1R Front brake reservoir
Heh Ian, What do you mean "join" ?
If the outlet is larger (9mm lip) you could look for a reducer to your hose size. Can you measure it?
I have an '77 Z1R too so am interested in how it goes.
Cheers, Rossco
Cheers, Rossco
Sorry Rossco66 - I hadn't spotted your response...
Anyway, I managed to score another fluid reservoir which stopped the leak.
I also scored another set of calipers, master, cable and lever from what must be a later model Z1R.
There are 2 differences - firstly the pistons are 42mm rather than 38mm (a 22% increase in piston area by my maths) and secondly the master cyclinder actuating lever is different - the later one has an offest pivot point (the earlier one being in the centre).
I've yet to test properly but it early signs are that these brakes are a huge improvement over the earlier ones!
Picture showing join where reservoir was leaking from:
http://i12.photobucket.com/albums/a233/ ... bny1cc.jpg
Picture showing different master cylinder levers:
http://i12.photobucket.com/albums/a233/ ... u3drkk.jpg
