07 ZX10 help needed
07 ZX10 help needed
07 ZX10 wont start
No codes
Turn key switch on tacho cycles nothing else happens , press start button, The motor turns over but ecu is not supplying a earth to pump relay, injectors coils
New ECU, Harness, relay box. Checked tip over, clutch, side stand, everything checks out OK but the wont start
Running out of ideas
Ian
No codes
Ian
Re: 07 ZX10 help needed
Silly question, but have you run the pump by independently connecting it to a battery? Or tested the pump for continuity?
I had an issue with a car not starting. I could hear the pump was not priming. Checks showed no error codes on the ECU and the ECU was not earthing the fuel pump relay (which earths the fuel pump at max volts). Turned out the swimmer fuel pump was open circuit internally, maybe rooted brushes, and the ECU detected that.
sounds like immobiliser.
is the edu matched with the key?
Indeed.Wattie wrote:sounds like immobiliser.
Or, as on one car I got running (which had already been through two auto elecs) , a cunning kill switch.
The new ecu has had the immobilizer bypassed, but I also tried running 5v to the blue wire on the immobilizer plug.
I have checked the kill switch off it on it crank on it will.
Not having taken an 06/7 ZX10 for a run before I am not sure on the safety cut out but checked the normal stuff, plus all sensors seem to check out ok
Sorted new ecu flashed with US file sorted that then bypassed the immobilizer Happy days . Turbo ZX10 to hit the track soon
- Kwakked Up
- Kwakked Up
06 zx10r - road
99 zx7r - trackie
77 z1000 - project
99 zx7r - trackie
77 z1000 - project
woot woot
