Quick question: are the ZXR750 L and ZX9B front ends exactly the same inc triples???
Are the shocks the same?
ZXR & ZX9 front ends
Re: ZXR & ZX9 front ends
No expert but I believe the B model 9 forks are longer that the ZXR.
Shock also has a built in external reservoir I think.
Are you looking to upgrade or just replace worn out parts?
1993 ZXR750 Track Bike
1994 ZXR750 Ongoing project
- Bike: ZXR750
The 9 forks are around 50mm longer than the 750L & the inner & outer tubes are heavier wall thickness. The B1 9s had the same caliper mounts as the 750Ls but B2 & 3s had the 90mm caliper spacing for the 6 pot Toki's, The 9 fork springs are stiffer too.
The triples are interchangeable but not sure if the offsets are the same.
Ex T.K.A. ZXR 750 RR
ZXR 7/9 L3 Streetfighter
Thanks for that, such depth of knowledge is what makes forums like this so valuable!
i asked because:
1/ I have a ZX9 front end to sell and wondered if it is limited to those only or ZXR use aswell
2/ If my 900 motor won't fit the braced M frame then I have a stock L frame I might put it in, and could use the ZX9 front end to build a bike with.
i asked because:
If you get stuck I think I have a set of L forks and triples in the garage.
Thanks Jim will keep that in mind
