Which years ZX6R to buy or avoid ?
- greenman43
Hi all, having got rid of my CBR 1000 (good bike, but I don't need a 1000 for the road or as a second track bike), I've decided I need a 600 supersports. My budget is about $6k.
Having heard of some 6s going bang, I want to do a bit of research, so which years of zx6r (or 636) should I pursue or avoid ?
Thanks,
Brian
Thanks,
Brian
- Glen
Re: Which years ZX6R to buy or avoid ?
Early 07 models had some issues with top ends but not many I don't think. We had one that dropped a valve but it was a tracky from almost new. For the road I'd stick to a 1000 though, the 600 will feel a bit gutless unless you're wringing its neck
- Glen
- greenman43
Thanks for the info Glen, I'm not averse to changing gears a bit, and I would prefer to have a 600 to enjoy at the track.
Brian
Brian
- smithy5
- Bike: Scooter
Fuel injection was introduced in 2002, so I wouldn't go any older
- greenman43
Thanks Smithy, was looking at no older than '04.
Brian
Brian
- Kwakked Up
I had an 04 zx6rr (600) which I bought as a road bike and converted to a trackie. Did some club racing for about two 2 years and really enjoyed riding it. She was nimble, had great brakes and was a cracker to ride but I always wanted more torque, probably had something to due with excess rider mass
It was a tough and reliable bike and the only issue I had was she would pop out of gear under power. ended up undercutting the grears to help prevent it. I was told by some that this was a common problem and others told be it was rider error.
06 zx10r - road
99 zx7r - trackie
77 z1000 - project
99 zx7r - trackie
77 z1000 - project
- greenman43
Thanks Kwakked up, good info.
Brian
Brian
Watch out for early B models as they are a favourite for stunters.
Pretty solid engines though but main issues would be frames being weakened at the head stock.
1993 ZXR750 Track Bike
1994 ZXR750 Ongoing project
- greenman43
Cheers Jim, pretty sure its an 05-06 I'll be chasing.
Thanks,
Brian
Thanks,
Brian
- Nelso
Leanne's old '05 model and Cath's '05 model both went bang and put a window in the block. Both were track bikes though.
- greenman43
Ah, not good. I thought these were the good ones, and the 07-whenever were fragile ? It's a concern, as I want to be able to do track days on it.
Thanks Nelso, much appreciated.
Brian
Brian
- tim
steer clear or early 07 models because of engine issue, 08's had the engine issue fixed and IMHO are a great robust and modern enough roadie and tracky, but if you can swing it go for an 09 or earlier - further fork upgrade and stronger mid range
- greenman43
Thanks Tim, good to know. The 09 or later is goong to be out of my proce range, so an 08 could be he go.
Chees,
Brian
Chees,
Brian
- EDU
For the road, I think the 05-06 would probably be a bit better than the 08... and for the track the 09+ would be better than either. You can probably find a 09+ for around that budget if you don't mind something with a bit more mileage on it. I saw one for 6.5K not too long ago with around 30K kms on it.
