modified rear brake pedals?
mohawk miss
Post by mohawk miss »
Due to current foot iproblem, I am having big issues making the slight inwards movement needed to use the rear brakes.
The ZZR only adjusts up or down, not in or out. I can't find anyone with an outward curved brake pedal to suit.
Any ideas or anyone know of a suitable replacement pedal?
Thx in advance
(not using the rear brake is not a suitable solution :roll: )
but it fell off.
Pilot of the Aloominum Falcon
Mister_T
Bike: GPx750
Re: modified rear brake pedals?
Post by Mister_T »
Can we see a pic of the brake pedal for reference?
I'm not familiar with that particular part.
If it has a folding tip, perhaps a tip from another bike could be adapted, perhaps even a tip from a gear lever as those can be a bit wider and rubberised.
If the tip is steel, perhaps the tip could be extended with some competent welding.
I take it the mod should be reversible when your injury is improved, in which case I would take the pedal off the bike and compare it with bike wrecker stock. If you are extemely lucky then you may find a suitable replacement gathering dust, if not you may find another ZZR600 brake pedal to modify and substitute.
If the stock brake pedal is all steel, that opens up the possibilites somewhat as steel would be easier to weld (for most people) than cast alloy.
Nelso
Post by Nelso »
If it's an OEM steel pedal, just use a big shifter and bend it out a bit.
