AIRBOX MOD 91-750
old zx750
Bike: ZXR750
AIRBOX MOD 91-750
Post by old zx750 »
I'm in the process of doing some mods to my 91-zx750, just pulled the tank and airbox/carbs what a design! can't remove air filter without carbs and air box , the cool air tubes run through the tank and cool air over airbox , air inlet horizontal at back of box so I plan to cut a couple of holes vertical above standard inlet.
pulled rear shock -stuffed and have a 09 zx9 I think, :D shock that should work i'll post pics -heaps more comp/rebound adj
weighed 03 gxr rear wheel 3kg lighter with a 190 tyre ,i'll check sprocket/ front wheel alignment tomorrow
going to weigh a 01gsxr front wheel also and disc/caliper fitment
replace the stock muffler with a straight through Yoshi ,any ideas on how much to jet up ?
zx750j,gsxr1100j,2x 90 gsxr 11/7 builds,gs1100gkd bore to 1200
triumph rigid build, gasser/hot rod build
old zx750
Bike: ZXR750
Re: AIRBOX MOD 91-750
Post by old zx750 »
Shock is about 30mm shorter,canister would hit batt box, make a bracket 30mm longer retain rear height adjustability
10 adjustments on comp/rebound easily assessable
old zx750
Bike: ZXR750
Post by old zx750 »
03 v 91 wheel
old zx750
Bike: ZXR750
Post by old zx750 »
raised srad gsxr handlebars -going under top triple clamp
old zx750
Bike: ZXR750
Post by old zx750 »
01-03 front wheel
old zx750
Bike: ZXR750
Post by old zx750 »
stock muffler v Yoshi alum
old zx750
Bike: ZXR750
Post by old zx750 »
inlet showing horizontal inlet ,is there supposed to be a forward facing piece that goes on back of air box ?
