has n e 1 done the install?
looks easy enough from the instruction but thought there may be something to look out 4!
also kit doesnt have bearings as some kits do
should this be changed at same time?
thanks 4 any info
install on a zx6r detent kit
- ozx6r
- Team Crim
97 - zx6r
05 - zx10r
05 - zx10r
- MadKaw
- Administrator
I put a factory pro shift kit and detent arm in the my zx9r.
Its about a 4 beer job with the hardest part getting the clutch basket bolt off. I hired a rattle gun and that solved the problem.
You will need a clutch cover gasket and thats about it.
The one I put in looked like this, but it was before they had the shift star.
The stock detent arm looks like a mini pizza cutter with a rivet holding the 2 pits of metal together. The factory pro one has roller bearings..
One of the best mods I made, eliminated missed shifts and shifts much quicker.
http://www.factorypro.com/images/ShiftK ... FT,H51.jpg
http://www.factorypro.com/Prod_Pages/prodk67.html
and theres an intersting letter on the bottom of the page..
