Hey all.
2012 ZX10R race bike
First lap all is well and it's a rocket ship. By the end of lap one it doesn't want to rev, still rides fine, but coughs and splutters a little and generally just loses all acceleration. Short shifting gears sort of seems to help it, but not really.
I noticed the fuel pump doesn't prime every time I hit the ignition switch.. So that's what I'm pointing at
Anyone experienced this before?
Thanks
ZX10R constant power loss
Re: ZX10R constant power loss
Have had similar symptoms on a carbed bike, turned out I had kinked the tank breather hose when putting the tank back on. Does the fuel cap suck air when opened after a lap? If not then your probably on the money with the fuel pump.
The tank cap isn't sealed fully yes, I found that out coming into turn 3 at QR (off the fastest part of the track to the slowest corner) when fuel was leaking from around the tank cap and the wind was catching it and blowing it across my visor.
I pulled it apart and the neck of the cap that mounts to the opening of the tank doesn't have a seal of any kind, I bodged it up with tape to stop the leak and the power issue persisted.
The fuel pump doesn't prime every time I hit the ignition switch (the electrical winding sound you're meant to hear when you switch the ignition on) so that's why I'm thinking that's it. And it's not showing any fault codes or any sort of indication on the dash. I've got a new pump coming just in case. But it's back with a mechanic (who has a dyno) to diagnose it and see what he finds.
Update for anyone interested
New fuel pump and tune fixed it! She's 100%. Beginning the drive from Brisbane to Phillip Island tomorrow
- Nelso
Leanne and I will be at PI (working with MEGA), Monday, Tuesday and Wednesday. We are both on ZX10's, hers is a 2010 and mine is an '04. Say hi if you run into us.
So its your fault I couldn't get a gig Nelso! !!!!!Nelso wrote:Leanne and I will be at PI (working with MEGA), Monday, Tuesday and Wednesday. We are both on ZX10's, hers is a 2010 and mine is an '04. Say hi if you run into us.
I had to pay for the first time in ages!!!!
Sorry mate I haven't been back on here since before the trip.Nelso wrote:Leanne and I will be at PI (working with MEGA), Monday, Tuesday and Wednesday. We are both on ZX10's, hers is a 2010 and mine is an '04. Say hi if you run into us.
I was on a plain black Gen 4 in red group
