ZRX CAT
billwest
Bike: ZZR1200
ZRX CAT
Post by billwest »
I read somewhere that the '01 model ZRX has a hidden CAT like item in the downpipes, which goes a long way to making them more restrictive. Anyone aware of that?
Has anyone seen these headers? They are single walled, internal diameter is 36 mm:
http://www.sandybikespares.co.uk/kawasa ... -468-p.asp
I'm going to take this bike apart, since it uses too much oil. I'm also looking at a 1224cc kit, seeing as it will probably need boring and o/size pistons and rings.
Bill.
Ride as if you own the bike!
ZZR1200 ('02), FJR1300 ('19).
bonester
Re: ZRX CAT
Post by bonester »
Not sure about that. I haven't seen any cats in my 01, but my 08 HAD a cat welded into the end of the headers with three spot welds. Somehow those welds failed and it fell off. :lol:
bonester
Re: ZRX CAT
Post by bonester »
Oh and my 01 goes better than my 08. Might be the de-snorkelled airbox/cams/debaffled stock pipe though.
billwest
Bike: ZZR1200
Re: ZRX CAT
Post by billwest »
bonester wrote:Not sure about that. I haven't seen any cats in my 01, but my 08 HAD a cat welded into the end of the headers with three spot welds. Somehow those welds failed and it fell off. :lol:
Strange that, how they fall off. I had the same happen to my ZX12R.
My Rex ('01) goes ok, with debaffled Yoshi bolt-on, but I'm looking for less restrictive headers. Dale Walker does a set, but a bit pricey.
bonester
Re: ZRX CAT
Post by bonester »
They're really heavy too the stockers. I have thought about 08 or so headers on my 01 because the stainless looks better. Zero maintenance though the 01. Occasional spray with Matte paint. :)
bonester
Re: ZRX CAT
Post by bonester »
http://www.ebay.com.au/itm/MOTAD-Edelst ... 3cdfd44a06
Strangely the 1100 are a lot cheaper
http://www.ebay.com.au/itm/MOTAD-Edelst ... 58b1e126f7
Both will fit your bike but maybe only the 1200 fit your can, For the price difference I'd buy the 1100 and get the can flange made up to suit 1200. Might only be a case of drilling correct holes too
billwest
Bike: ZZR1200
Re: ZRX CAT
Post by billwest »
I'm told the inside diameter of the Motad is the same as for the OEM. It just doesn't have that restrictor in it.
billwest
Bike: ZZR1200
Re: ZRX CAT
Post by billwest »
Got my hands on a used Akropovic complete system, in pretty good nick!
:D
bonester
Re: ZRX CAT
Post by bonester »
Akro are arguably the best pipes out there- good work!
billwest
Bike: ZZR1200
Re: ZRX CAT
Post by billwest »
I have to thank my offspring for finding that one for me. Japanese auction site.
Next job: new pistons and rings. This thing uses too much oil. May upgrade to a 1224cc kit.
Nelso
Re: ZRX CAT
Post by Nelso »
billwest wrote: I'm also looking at a 1224cc kit, seeing as it will probably need boring and o/size pistons and rings.
Bill.
Yes, it will need to be re-bored and Nikasilled. Ape, in the US, have an exchange program for cylinders for the 1224 kits, which would be much cheaper than getting it done here. JE make the pistons, which are 12.5:1 comp.
I so want to do this to mine, too.
billwest
Bike: ZZR1200
Re: ZRX CAT
Post by billwest »
I think that the amount of oil I used on my Phillip Island trip was way over the the top, so I don't think it is just rings. But, I can't find oversize pistons from Kawasaki.
http://zxzone.com/pistons.html
And this from APE regarding the 1224cc kit, rebore and replating (their kit comes with pistons, rings, piston pins and clips):
Hello Bill,
The exchange kit is $984.00 USD
I head gasket is $80.31 USD
Shipping by USPS Intl Priority mail I estimate will be around $100.00 USD
We must have your exchange cylinder block in hand along with your
payment before we will ship out our kit.
Regards,
Pat at APE
J.B
Re: ZRX CAT
Post by J.B »
Their kit is pretty well tried and tested. I went through them for mine 8)
billwest
Bike: ZZR1200
Re: ZRX CAT
Post by billwest »
Did you put other cams in? What about the ignition advancer? Mine is currently +4 degrees. With the increased CR it may have to go back to standard.
Bill.
J.B
Re: ZRX CAT
Post by J.B »
billwest wrote:Did you put other cams in? What about the ignition advancer? Mine is currently +4 degrees. With the increased CR it may have to go back to standard.
Bill.
I've got a set of Kwick's Yoshi replica cams in mine.
I changed the advancer back to stock as well but I also have a different ignition unit. You'll be better off with the stock timing if you go to higher CR.
