09 zx6r - Kleen
- MadKaw
- Administrator
09 zx6r - Kleen
Sooo, this thing pops like a bastard, so I figure I'll remove the KLEEN (for off road use only of course).
Does it throw a light if I toss all the crap out.?
If so, is it just simple jump wire or something else.?
- EDU
Re: 09 zx6r - Kleen
Not that I can remember... the only light you'll get is from removing the exhaust servo from under the seat. It will probably still pop without the clean though... mine popped all they till it got a new map.
- MadKaw
- Administrator
Re: 09 zx6r - Kleen
Yeh, its just running the dynojet supplied map for an akro slip on, it definitely needs a custom jobby.EDU wrote:Not that I can remember... the only light you'll get is from removing the exhaust servo from under the seat. It will probably still pop without the clean though... mine popped all they till it got a new map.
Re: 09 zx6r - Kleen
Kawasaki wsbk team don't even use block off plates. They just join the hoses together Madkaw garage style
- fireyrob
Re: 09 zx6r - Kleen
My memory is vague after 4 years but it involved:
- Disconnect the tube running from the airbox.
- Block the airbox outlet up so its sealed.
- Cutting a shorter length and running the tubes across so the plates just run from each other. This is cheaper than buying block off plates.
- Leave the plug connected but seal it up with tape and tie it up so it doesnt float about.
- Now I cant remember if I tied off the extra tubing attached to the plug. Just turned it over on itself and cable tied. I cant recall sorry.
- fireyrob
Re: 09 zx6r - Kleen
This is the 07-08 attached. The system is the same but like I said dont buy block off plates. Just use a length of tube and it acts the same as block off plates
http://www.kawiforums.com/how-tos-faqs/ ... r-mod.html
- MadKaw
- Administrator
Re: 09 zx6r - Kleen
I knew my cheapskate ideas were the best....Wattie wrote:Kawasaki wsbk team don't even use block off plates. They just join the hoses together Madkaw garage style
Yeh wasn't going to buy any plates just connect the 2 together, just wasn't sure if it gave an FI light... Some say yes, some no.. Some say you need a resistered plug, others just a staple jumper..?
- Kermit
Re: 09 zx6r - Kleen
This,fireyrob wrote: Leave the plug connected
We did this last time with my old bike, unplugged; the light kept on.
Block off plates helped with minimizing pops but doesn't get rid of it all.
- Kermit
Re: 09 zx6r - Kleen
If you want to do the resistor mod, look hereMadKaw wrote:Some say you need a resistered plug, others just a staple jumper..?
- MadKaw
- Administrator
Re: 09 zx6r - Kleen
Thanks,
Went the easy way, routed the tubes into each other, blocked the air box hole and left the unit in there.
Heaps less popping...
in the garage anyway...
- EDU
Re: 09 zx6r - Kleen
And no lights, right!?
- MadKaw
- Administrator
Re: 09 zx6r - Kleen
yep, no light..
- Team Monster
Re: 09 zx6r - Kleen
Is this the generally the same with a 2010 onwards's Z1000????fireyrob wrote:This is the 07-08 attached. The system is the same but like I said dont buy block off plates. Just use a length of tube and it acts the same as block off plates
- fireyrob
Re: 09 zx6r - Kleen
A quick google search said something about it being even more simple. Like blocking off one tube. Let us know how you go
- Team Monster
Re: 09 zx6r - Kleen
Maybe I have a different googlefireyrob wrote:A quick google search said something about it being even more simple. Like blocking off one tube. Let us know how you go
