2012 ZX10R blocking plate
Juggy
Post by Juggy »
I remember reading somewhere about blocking a "2nd air" when fitting an aftermarket exhaust to my 2012 ZX10R.
Have you guys all done this? If so how did you do it and where did you get the blocking plate?
Had mine flashed but it's still getting stuck when the throttle is only slightly open.
Feels like it's getting puled back as I am just opening the throttle then it just takes off. Anyone else having this problm?
Thanks
This is my signature and it can say whatever I want.
Re: 2012 ZX10R blocking plate
Kawasaki wsbk team don't even use block off plates. They just join the pipes together
Maccarocks
Post by Maccarocks »
Same as me Wattie...!!
I just cut a pipe to fit neatly between the ports and cable tied it in place... works exactly the same for basically nothing ;-)
Macca
Maccarocks
16' - Z1000 (Road)
Juggy
Post by Juggy »
Well that sounds better.
Have either of you got photos?
How long did it take and is it very technical or fairly straight forward?
JimZXR
Bike: ZXR750
Post by JimZXR »
I had a mate mill me out some from plate aluminium using the old plates as a template!
Granted it's only on a ZXR750 but the idea should be the same!
Or Graves Motorsport in the US sell them cheap-ish!
1993 ZXR750 Track Bike
1994 ZXR750 Ongoing project
zxsixr03
Post by zxsixr03 »
Juggy wrote:I remember reading somewhere about blocking a "2nd air" when fitting an aftermarket exhaust to my 2012 ZX10R.
Thanks
I have a unused set if u really want them?
