ZXR750 J-M countershaft seal
Got a small oil leak and looks like its the countershaft sprocket seal - anyone know if these can be replaced in situ or do you need to take the whole alloy cover off (and if so is this a straighforward job? Looks like it is but prefer to check first!)
- willrcr15
- Bike: ZXR750
Re: ZXR750 J-M countershaft seal
Hi Fifer, I just had to do mine as the little clutch shaft seal had died & was filling the clutch slave cylinder, it can only be replaced from within.
Its straight forward once you get everything out of the way, I think the side stand has to come off as well, don't forget to drain the oil first.
You'll need a new gasket for the side cover & I'd recomend replacing the clutch shaft seal while it's off, I replaced both seals, hopefully thats the last time it has to ever come off.
Note: I tried to replace the shaft seal with something off the shelf from Skefco & luckily they were switched on & saw that it was a different type of seal, not one for a spinning or rotating action but for a plunging type action so I just ordered genuine parts & am happy I did.
Looking forward to the quiet life !
2 Honda NSR 150 SP's for the kids
94 ZX750R
97 Suz GSXR750
95 RGV250
90 FZR 250
81 XS1100
94 ZX750R
97 Suz GSXR750
95 RGV250
90 FZR 250
81 XS1100
Many thanks for the reply, parts on order and in soon. One more thing underway to get this bike up to scratch.
