Any advise
Stevojumps
Any advise
Post by Stevojumps »
I'm thinking of pushing the forks through the tripple clamp on my zx12 just to see if it will steer a little bit quicker , already got a 190 on the back and that helped.
From what I've read people seem to drop them between 5 -10mm , has any one done this and did it make much of a difference?
I can't really raise the rear because I'm a short arse :roll:
Any advise would be helpfull.
captain slow
Bike: ZXR750
Re: Any advise
Post by captain slow »
Stevojumps start with 5mm and go from there
JimZXR
Bike: ZXR750
Re: Any advise
Post by JimZXR »
Totally different bike I realise but after dropping my ZXR750 5mm through the forks the difference was unreal! Tipping in way quicker!
1993 ZXR750 Track Bike
1994 ZXR750 Ongoing project
MAXUMIS
Re: Any advise
Post by MAXUMIS »
I dropped mine 6mm's and it made a very noticeable difference in tight corners with a 190/55 rear . :D
life starts at 200 kph!
Stevojumps
Re: Any advise
Thanks for the feedback guys , I'll try 5mm and go from there.
Re: Any advise
Dont do the fork thing, your better off to raise the rear ride height on the shock with spacers on the ZX12R otherwise you WILL scrape the fuk out of your fairings if your suspension is stock.
Not that I would know much :lol:
Nelso
Re: Any advise
Post by Nelso »
Jonno wrote:Dont do the fork thing, your better off to raise the rear ride height on the shock with spacers on the ZX12R otherwise you WILL scrape the fuk out of your fairings if your suspension is stock.
I'd be listening to Jonno's advice regarding ZX12s. I've not seen anyone steer a 12 better than him and Gos. :kuda:
Stevojumps
Re: Any advise
Thanks for the heads up Jonno , I had heard of that happening.
It's just that I'm a bit of a short arse and on the balls of my feet now :roll:
SteveW
Re: Any advise
Post by SteveW »
Im running a 190/55 on mine, raised the ohlins rear 5mm, might try the full 12mm the ohlins gives..
ZX-12R B6F
