regulator rectifier for 05 zx10r need urgently. !!!HELP!!!
- Gazza
If anyone can help me out with a regulator rectifier for my 05 crim
that they have spare and would like to sell, I would be more than happy to take it off your hands.
Need it ASAP if possible.
Thanks in advance.
Thanks in advance.
2005 zx10r
Re: regulator rectifier for 05 zx10r need urgently. !!!HELP!
With the exception of the plug, reg recs are pretty generic as long as you buy a three phase (3 yellow wires) as opposed to single phase. (most bikes aren't single- z440 only bike I have owned with single.) So as long as you get one with reasonable current capacity, you should be able to make it work.
Yeah I like Kawasakis.
- Gazza
Thanx bonesterbonester wrote:With the exception of the plug, reg recs are pretty generic as long as you buy a three phase (3 yellow wires) as opposed to single phase. (most bikes aren't single- z440 only bike I have owned with single.) So as long as you get one with reasonable current capacity, you should be able to make it work.
I'll check at the wreckers and see if they can sort me out.
What's the best way to check current capacity?
2005 zx10r
Dunno but would look for one off a larger bike
- badruss
Hope you got it sorted, have had two die on my Gumby in the last 18 months, rewound both times under extended warranty, hope this one lasts a little longer.
A more permanent solution would be good to know if someone has a good idea
I think you are talking about Stator, Russ.
- badruss
Oops, yeahbonester wrote:I think you are talking about Stator, Russ.
- Gazza
All sorted peeps.
Went to Metro moto spares this arvo and found one on a zx14 cost $125.
Hooked it up when I got home and now charging at battery 14.2V
very happy.
But now have a second hand stator I don't need
very happy.
2005 zx10r
Kewl!
