Hi all,
Just looking to gather a little information for my ZRX-suspension-goes-into-shagged-out-MkII project. I've recently been lucky enoughto score a pair of '07 ZRX12 forks off MKY on this very forum, and now I'm trying to find out about which triple clamps to use.
As I understand, fork diameter at 43mm is the same across all years of the 1200. Where I fall a little flat is in the clamps - my usual source of info for part number comparison, http://www.buykawasaki.com, crashes and burns given the ZRX was not sold in the US after '05. I've yet to go and look at OEM specs for trail, but my question : do all models of the 1200 use the same triple clamps, or are there differences ? If so, which years should I be chasing and why ?
Thanks in advance,
Brian
ZRX forks and triple clamps
- greenman43
- Nelso
Re: ZRX forks and triple clamps
All 1200 triples are the same as far as I know. They are definitely different to the 1100's and there is a difference in the fork internals between the early 1200 and the later models, but nothing else changed on the 1200s apart from colours.
- greenman43
Thanks Nelso. Looking at some specs on http://www.zrxoa.org/webpages/generalin ... specs.html, the 01-03 shows 4.1 inches trail while the 04-05 is apparently 4.2in. Presumably less offset in the later clamps, although I can't imagine 2.5mm trail is going to make any real difference at the speeds I'll be wobbling round at !
Brian
Brian
The 04-08 are all the same as far as I know
- greenman43
Thanks Laithe
