ZZR1100 broken ignition wire
The white wire inside the actual key ignition unit has come off and after pulling things apart to get at it, there are no real signs of where it was originally soldered. I connected it to the red wire but even when the bike is on lock and the key removed, the tail light stays on! HELP!!!!!!!
Re: ZZR1100 broken ignition wire
No one replied to your concern on your very first post ! since May 2013 !
Damn !
I'm guessing that you had it sorted since ?
Damn !
