Hey All
My discs are warped and i don’t want to spend $400 each side for OEM to replace them.
I’m looking at these...
http://www.s3performance.com.au/front-b ... -3383.html
Has anyone used these before? Or can someone recommend me something else that not off the show expensive?
05 ZX6R 636 Front Rotors
Re: 05 ZX6R 636 Front Rotors
I've used these on a number of bikes and they work well but....to get them to work well they have to be ground and have the buttons tweaked to loosen them off so the rotors float properly. The guys that run the business seem like good guys, provide a good service and they have a machinist that will do the grinding/adjustment at your expense....if you do decide to go with them I would strongly recommend you get them machined. (And don't use EBC HH pads with them either, the rotor material doesn't seem to like them which in my experience caused alot of overheating. Galfer or Ferodo work well.)
Sweet thanks for your reply mate =)
They advertise them as a direct swap for the OEM rotors, but you need them machined at your expense for them to fit??!! Shouldn't that be their cost if they don'y fit properly?
I only ask cause I am after some as well for the same bike.
This is my signature and it can say whatever I want.
- z900/zx9
got 2 sets of EBC rotors for my 02 and 2001 zx9 from rockymouintain work well with ebc hh pads,price was pretty good.
