ZX6 J1 Clutch Cable...
- Administrator
- State: Tasmania
Well coming home form a job interview, i notice the 'ol clutch feels funny and isn't springing back..
turns out I have 2 main segments holding it on, the rest have freighed...
So at a guess.. 2 days riding would be my limit of risk..
Had to cut away the freighed bits of cable because they wouldn't let me adjust it at all, and nearly dropped the bike twice trying to test whether it had enough pull... *sighs*
Anyway, anyone have any idea what I'm up for for a new clutch cable???
do i need the entire cable or would I just be buying the core?
Bearing in mind money is tight, and I have to use the bike for commuting.. So if I start the job one night, I have to be able to ride it to work the next day.
Dan
Dan
Ducati Monster S2R1000
- mike-s
re: ZX6 J1 Clutch Cable...
Talk to a wreckers, you might be able to get one cheap (i.e. 10-20) if on the cheap sounds the way. Otherwise it'd be a $30-60 part. I'd recommend replacing inner & outer at once unless you just want a hack to get you to/from work until you can replace teh whole thing. In which case you might be able to hook something (very dodgy) up with the old end lugs and a bit of multistrand steel cable from a pushbike shop. (as i said, VERY dodgy)
- MadKaw
- Administrator
I believe its the same as the zx9 one and they cost about $25 to $30 brand new. Don't risk getting one from a wreckers as you won't save much and it may have a similar problem.. I found that from experience..
- Aussie Ninja
I did mine about a year ago. Got a non genuine new complete cable from my local shop for $32.
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
1998 ZX6R R.I.P.
2011 ZX10R
- Smitty
I just bought a complete GENUINE speedo cable for the GPx...
$22 inc GST....
so i reckon a clutch cable won't be much more...
ciao
$22 inc GST....
ciao
- Jonno
- Mobile Chicane
I think from memory a guy makes custom cables to order from his home .
We use to use him years ago when I had the business in Thomastown, does good work.
Auto cables Pty Ltd
3 Eliza Cl.
Greensborough.
Ph: (03) 9434 1410
MAP
Auto cables Pty Ltd
3 Eliza Cl.
Greensborough.
Ph: (03) 9434 1410
MAP
- Administrator
- State: Tasmania
I'll give him a try.
Cosway's $35.80
And again she managed to pissed me off..
Like fark, what because I rang up for a price on something I'm expected to come in and buy it...
Cosway's $35.80
- Administrator
- State: Tasmania
Tried him.. no go, cause he needs a sample, and I need the bike to get to and from work...
Race Rep can get one in from Kawasaki in 2 days for $31.90
Brighton Kawsaki $34.00
So looks like I might as well save myself the hastle and pick it up from Cosways on my way home from work.
- Aussie Ninja
Re: re: ZX6 J1 Clutch Cable...
Nah. With no idea what I was doing to start with I knocked it over in a bit less than a hour. You have to take off the right faring to rout the cable. Both ends go in via standard keyway type attachment (turn the cable to slot and pull through). Once the new cable is on use the adjustment at either end to get the slack right and you're on your way again.Yankee wrote:is it a tough job to do? j/w
1998 ZX6R R.I.P.
2011 ZX10R
1998 ZX6R R.I.P.
2011 ZX10R
And if you do it that way you dont have to take any fairings offmike-s wrote:the cheats way is to loosen the end holddown points on the current cable, *FIRMLY* tape the new cable to the old one and make sure the ends wont catch on anything, then proceed to pull the new cable through.
The Doc says my blood is green. Thankfully, there is nothing he can do to help
05 ZX6R Green Roadie
95 ZX6R Red Trackie
95 ZX6R Red Trackie
- mike-s
oh and another tip. make sure you put the cable in the right way around. nothing makes you feel like a tosser like pulling the cable through, cussing and swearing as you jiggle it htrough and then realising that you don't have it the right way around.
note, i've neer done it, but the thought occured to me then and i cringed.
