Power Commander zx6r 2010
Fossi
Post by Fossi »
Hi Guys,
I need some advise. I'm looking to get better performance from my zx6r 2010 and looking at power commanaders. I have a MGP growler exhaust on the bike and want to know if installing a power commander will deliver increased performance.
What sort of BHP increase and I expect..? who in Melbourne can install..?
Any info would be great, thanks
Re: Power Commander zx6r 2010
It shouldn't increase your hp figures by much at all.
It will however smooth out your throttle response, power curve and fuel consumption.
You'll be lucky to get and extra 2-3hp
Strongest improvement for the road is dropping a tooth on the front sprocket. It will feel like you gains 20% more power for $20. Really how often are you going over 250kms anyway?
Jonnymac
Post by Jonnymac »
Listen to Blurr he is wise.
But if you don't want to......
To see any improvement in hp you need a full system and and a pc. Even then it will only be around 8-10hp.
Pc alone will only give you smoother throttle and maybe 1hp if your lucky. But if you do chose to do any of these things Dynoverks in boronia is the place I use in Melb.
Go and have a chat to Deano and tell him I sent you there.
Blurr wrote:Strongest improvement for the road is dropping a tooth on the front sprocket. It will feel like you gains 20% more power for $20. Really how often are you going over 250kms anyway?
Just do this!
Do the front sprocket thing, best bang for your buck.
EDU
Post by EDU »
And if you do go after the hp improvement a PCV might give you, get the Bazzaz QS instead and enjoy the awesomeness of its quickshifter as well... :kuda:
Do the front sprocket either way, can't lose!
Fossi
Post by Fossi »
Does dropping a tooth limit top end speed..? I do 250KPH maybe twice a track day, twice a year, will it give me better bottom end.
Is 250km/hr on the rev limiter in 6th?
Doubt it.
Drop a tooth!
Jonnymac
Post by Jonnymac »
Realistically I doubt your doing 250 I assume your talking PI?
If it indicates your doing 250 its more like 220.
Trust me I have the same bike with one tooth down at the front and one up at the rear and the last time I was at PI I was doing a true 244km/h from a GPS topping out in 6th at the end of the straight
Fossi
Post by Fossi »
Thanks for the feedback guys, always good info on this forum, I'll be dropping a tooth on the front. I'll report back after the next track day. Cheers.
Fossi wrote:Thanks for the feedback guys, always good info on this forum, I'll be dropping a tooth on the front. I'll report back after the next track day. Cheers.
In the meantime - DO THIS - http://www.ksrc-au.com/phpBB3/viewtopic.php?f=8&t=42631
Fossi
Post by Fossi »
Hi guys, thought I'd supply an update, i dropped a tooth on the front sprocket and fitted new tyres dunlop Q3's. Bike feels awesome, consistent 240klms down the straight at PI. Thanks for the feedback, awesome mod for the bike.
Baddie
Post by Baddie »
Buy a zx10r..Shit loads power and shit loads of fun.
Forget PCV...look into Woolich racing and they are Aussie based.
http://www.woolichracing.com/products/k ... shing.aspx
http://superbikesource.com.au/
For aftermarket racing products, from Annitori Quickshifters to Race fairings.
http://tarmactalk.com/forum/forum.php
