Stalling z1
spunjbaall
Stalling z1
Post by spunjbaall »
2010 z1 has recently started cutting out, it seems to do it hot or cold but as far as I can tell it does it on the down change as I'm releasing the clutch. Sure it's not me I've never done it before, it doesn't do it on every gear change. Plus it sometimes cuts out if I rev it in neutral it'll cut out out as it comes back down to idle speed .
Any ideas.
Re: Stalling z1
Wind the idle up a bit.
spunjbaall
Re: Stalling z1
That makes sense doh!. What should it idle at, any ideas.
Re: Stalling z1
Normally about 1000-1100rpm?
Did you recently change the exhaust or
Air filter or anything?
spunjbaall
Re: Stalling z1
Was about to change the air filter but was supplied the wrong one, so had to clean the old one and put it back in, should pic up the right one mon/tues, but this started about a fortnight ago.
Re: Stalling z1
Sometimes when you change a filter, exhaust or removed an exhaust bung that the idle needs to be adjusted.
The z1000 filter is always a
Saga. They changed at some stage.
spunjbaall
Re: Stalling z1
Should get the filter tomorrow, change that then have a look at the idle, took a bit more notice today it idles at about 1100 when the chokes on and drops to about 700 ish when it warms up and comes off choke.
Re: Stalling z1
Probably a touch low
Re: Stalling z1
Yeah, that sounds too low.
spunjbaall
Re: Stalling z1
O.K. Oil changed the right air filter in this time, idle speed adjusted. Everything seems to be tickety boo!.
Thanks.
