'98 ZX6R Trackie
murchy
'98 ZX6R Trackie
Post by murchy »
Hi guys,
I've just recently bought a 1998 ZX6R to convert from road to track.
Picked it up for a great price ($1000) as it's been sitting idle for ~18 months. As such, it needs a lot of TLC to get it back in shape.
Turns out it needs new discs and pads on the front, so I thought it'd be a perfect opportunity to do a complete front end replacement rather than bother with spending $2-300 on discs/pads alone.
Any ideas on an 03-05ish era front end that would fit for a simple swap?
-Tom
98green
Re: '98 ZX6R Trackie
Post by 98green »
If you swap to the newer front end you will need the stem pressed out of the 98 and pressed into the newer, then you will need the whole lot at the front cos the hub size is different..
