welding a ZXR alloy tank?
Jason
Bike: ZXR750
Post by Jason »
G'day again..
Anyone happen to know what type of aluminium is used on the ZXR750 fuel tanks? I'm thinking probably 6061-T6?
Reason is, I need to do a welded modification to a spare alloy fuel tank I have to make it suitable for road use. Obviously in a previous life it has been used on a race bike & the underside has been deepened to increase capacity, but it won't fit on a standard bike with the standard coils & airbox in place.
Advice on what aluminium to use from anyone with experience welding these tanks would be much appreciated.
Jason
StuMiller
State: Tasmania
Re: welding a ZXR alloy tank?
Post by StuMiller »
Check the specs on ER4043 and ER5356 grade filler rods.
Are you tig welding? If so, you'll need an AC/DC machine. Preferably with a HF start.
2007 ZX6 - Road bike
StuMiller
State: Tasmania
Post by StuMiller »
Check out this place, it might help you out.
http://www.bocworldofwelding.com.au/
Nice Plug stu :P
Shows what I know but I thought the tanks were steel :shock:
born green
Post by born green »
robracer wrote:Nice Plug stu :P
the RR was alloy,
had a laugh at stu's plug too
96 ZX7R roady
95 tickford XR6,
StuMiller
State: Tasmania
Post by StuMiller »
Only trying to help.....
Jason
Bike: ZXR750
Post by Jason »
Thanks guys...
It will be TIG welded, not by me though.. will get one of the guys who know what they're doing where I work.
Jason
yzr750
Post by yzr750 »
Jason wrote:G'day again..
Jason
Highly unlikely to be 6061T6, that alloy is not really suitable for fabricating, it is more likely to be something like 5083.
JimZXR
Bike: ZXR750
Post by JimZXR »
If you're putting it back onto the road I have a spare tank from my L (93-95) model track bike if you fancy a swap?
1993 ZXR750 Track Bike
1994 ZXR750 Ongoing project
Jason
^^^^ this. 6061T6 is the sort of alloy you machine to make.....things. It isn't what you use to build a fuel tank.
StuMiller wrote:Check the specs on ER4043 and ER5356 grade filler rods.
Heh Stu - what sort of Tig welder would you recommend for welding aluminium ?
I have been welding since 18, stick welding, oxy and also have a nice little gasless Mig for the small jobs - so I have a pretty good understanding of what is needed to weld properly - but I have NFI about Tig's or what would be a good unit for a small home workshop.....
StuMiller
State: Tasmania
Post by StuMiller »
Depends on your budget. You can pick up a good 200 amp DC HF start tig for under $1000.
If you want pulse, gas purge, 2T/4T, up slope and down slope, you'll pay more.
To avoid unnecessary plugs, PM me and I'll email you some details.
no worries, pm on the way......cheers :kuda:
timmyrocks
Post by timmyrocks »
Definatly get HF start, we get one at work that's not and I hate it :x
Off topic but gos what's your gas less mig, Ill prob get one but have heard mixed things about them :)
Team Crash "09"
WR125 2004 Husqvarna :P
I'll have to check mate - but it is just a cheapie. It does work well though, I knocked up a massive cage on the back of PC's ute last weekend, nailed the job in 2 days wait till you see the photos !! :shock: Its a lockable cage so he can secure all the band gear in the back, its getting a proper tonneau cover made up shortly. Should look really good when finished.....
The gasless Mig was perfect for this job - heaps of small spot welds to secure the mesh to the frame, only used thin-wall RHS 20mm for the frame, this Mig only has a Hi/Lo power switch so just did the lot on Hi.
Was also a good chance to test-run the new welding mask I picked up earlier this year......one of those instant ones that have a reaction time faster than the speed of light !! :lol:
