Variable rate throttle kits.Anyone used one?
webcase
Bike: Honda
Post by webcase »
Has anyone had any experience using one of these kits or similar brands?I'm interested in trying a few different reels to find the ideal one for the street.(I'm looking to increase rather than reduce the twist.Pensioner pack ;) )
http://www.motionpro.com/motorcycle/art ... ttle_kits/
MAXUMIS
Re: Variable rate throttle kits.Anyone used one?
Post by MAXUMIS »
I have a rifleman setup,cheap and works well.
life starts at 200 kph!
Increase twist as in, less acceleration per turn?
Rifleman doesn't increase the twist
I am curious though, why on earth would you want it longer??
Jonnymac
Post by Jonnymac »
I've got that one, reasonably happy with it, I've got the 2nd quickest throw on it and I would like the quickest but I can't use it.
When it's put in,due to the cables they supply that you need to use,it actually doesn't allow the throttle to return completely and it sits there revving at 2000rpm.
Jonnymac
Post by Jonnymac »
Blurr wrote:Rifleman doesn't increase the twist
I think he said something about old. Shouldn't you be looking at this too Blurr........ :-b
webcase wrote:Has anyone had any experience using one of these kits or similar brands?I'm interested in trying a few different reels to find the ideal one for the street.(I'm looking to increase rather than reduce the twist.Pensioner pack ;) )
mate those kits only reduce the amount of throttle travel - not increase it.
The slowest throttle rate you will get, is with the OEM throttle. Stick with that :kuda:
Fark off. ;)
I take it you are coming to PI Or ECto show me around then you young pup.
MAXUMIS
Post by MAXUMIS »
You are write,i just thought wrong :lol: i have never seen anyone that wants more twist :?
Yeah mate me either, I had to read it a couple of times for it to sink in as well
MAXUMIS
Post by MAXUMIS »
GP is on ,on ONE then ten ;)
I want mine replaced with a light switch if I can.. :lol:
webcase
Bike: Honda
Post by webcase »
:lol: @ the light switch.
Seems i'm Robinson Crusoe.As Gos said looks like they all shorten the twist.I misread it as either way.Was just a thought as due to losing my car i'm commuting on a 1000 and thought the idea of a gentler throttle may be useful.
Just ride a gear higher ;))
Much cheaper
RichB
Post by RichB »
Check the diameter of oem, and compare to the revolver pulleys, the slowest pulley is probably smaller than oem I'd be guessing. You get a decent housing and cables in the kit, but doesn't sound like you need it. Can also interfere with bikes with large integrated switchblocks and mcyl arrangements depending on the model.
