Wheel alignment tool
Jonnymac
Post by Jonnymac »
Hey peps,
Does anyone know a local supplier of something similar to these muzzys wheel alignment tool?
http://www.muzzys.com/catalog/tools.html
Jonnymac
Post by Jonnymac »
I guess not :-(
Not sure mate. I did think super bike supply used to have one but I can't find it.
oldman
Re: Wheel alignment tool
Post by oldman »
A piece of string will do the same thing and save you a hundred bucks. I'm sure one of the members in Australia could show you how to do it. Cheers..
Jonnymac
Post by Jonnymac »
oldman wrote:A piece of string will do the same thing and save you a hundred bucks. I'm sure one of the members in Australia could show you how to do it. Cheers..
Thanks, yeh I know I can do it with string, but I believe this will be quicker and more accurate.
born green
Post by born green »
Jonnymac wrote:Hey peps,
jonny give tristan from redline a ring, 9792 5025. he has the best wheel alingment tool ive seen, dont know where he got it, but im sure he can tell u, or get u one.
96 ZX7R roady
95 tickford XR6,
Johnnie5
Post by Johnnie5 »
ebay chain alignment tool
there is a few different devices a bit different to what you are looking for , but far cheaper and as effective
Maddog
Post by Maddog »
Maddog wrote:This one's in Vic Jmac
http://www.ebay.com.au/itm/Rear-axle-al ... 564345acff
I can't see how that can align the wheels ? It just aligns the rear axle with the swingarm pivot - not the front wheel.
It might be old school - but string-lining a set of wheels is a piece of piss and really accurate. It works. And it doesn't cost $140 !! :lol:
redmistracer
Bike: ZXR400
Post by redmistracer »
Sharp engineering had something close to it.
dilligaf
Post by dilligaf »
Jonnymac
Post by Jonnymac »
That's right it's instead of using the lines on the blocks to align the rear wheel. And your right it doesn't align with the front wheel but if it's true in the swing arm then your nearly there.
redmistracer
Bike: ZXR400
So which is better or do they fix different things. I assumed having the axel line up with the swing arm would give your sprockets alingnment.
Running strings will show if your bent somewhere (Forks, Triples/Headstem, Frame or Swingarm) or am I missing/thinking something else.
well there has always been speculation on the accuracy of the marks on most swingarms over the years :lol: so I can understand why this check would be a good one. What about the laser aligner ? This just sits on the rear sprocket and runs a laser light over the chain aimed at the front sprocket - this effectively aligns the rear axle to the chain run so the chain runs in a perfect straight line from the front sprocket......
redmistracer wrote:....So which is better or do they fix different things. I assumed having the axel line up with the swing arm would give your sprockets alingnment. Running strings will show if your bent somewhere (Forks, Triples/Headstem, Frame or Swingarm) or am I missing/thinking something else.....
well if you just want to check the chain run for maximum chain life - making sure the rear axle is perfectly aligned to the swingarm with the use of either that big aligning tool, or a laser aligner used off the rear sprocket - both of these will do this.
String-lining just makes sure the wheels are perfectly aligned - absolutely required if you want your bike to handle as well as it can. If the stringlining results in the chain run being misaligned - then you start looking for bent swingarms or maybe triple clamps etc. There are simple remedies and things you can do to check fork straightness / triple clamp alignment without removing forks from the frame.
First thing you need is 3 broomsticks !! :lol: :lol:
redmistracer
Bike: ZXR400
So every good race kit should have a roll of string and 3 broom sticks. A fold out chair and ??????????????????????????????
