All the plug spanners I have are to big to fit down the hole in the motor
Does anyone know if this is a standard Kawasaki Item That you can buy over the counter?
Plug Spanner L3 ZXR750
Re: Plug Spanner L3 ZXR750
I had a bugger of a job with mine, I got a standard plug-socket to fit it ok but the problem was the depth of the hole and the awkward accessBionic wrote:All the plug spanners I have are to big to fit down the hole in the motor
If the end I had to buy two short extension bits with a knuckle to join them together....nightmare
- Smitty
re: Plug Spanner L3 ZXR750
hehehe
the standard Kwaka jobbie is a thin wall long tube type socket
(and used on most of the later Kwaka inline fours)
the car type ones just don't do it....
got mine from BKwaka....a long time ago for something like $5
today???
today???
- 99coconuts
the socket that came in my cheapo $100 supatool box fit, but its as tight as a nuns nasty
i taped the socket up to the extension and lubed it up before squeezing it in (you dont want it getting stuck in there)
and then i had to use a wee little elecetronics grabber thingee to pull the plugs out cos they refused to come out with the socket
i much prefer my GFs XJR400 for changing plugs, dont even have to take off the tank....
racing hondas is like running in the special olympics
win or lose, you're still a honda rider...
99 ZX7R streetfighter
76 HJ Wagon kiddiekart
71 HQ coupe
http://www.99coconuts.com" target="_blank
jeebuz, 3 kids now.... anyone want one? free to a good home!
71 HQ coupe
- Team Kitty Litter
- Bike: ZX7R
"Supertool", cheap crap available from Kmart or supacheap, make a plug spanner that does the job perfectly. It's a little snug as it goes past the O-ring in the valve cover, but a liitle grease makes it work a treat. Just make sure it's all clean so you don't damage the O-ring.
*edit*looks like nuts beat me to it.
- javaman
- Bike: GPz900
What I did ...
1. Bought $11 spanner from brighton Kwaka.... too short !
2. Used my Honda Civic plug wrench .. worked for cylinder #2 & #3, but not for #1 and #4 since too long and hit the frame !!!
3. Bought $6 spanner from Supercheap auto... worked by using short extension and add another short extension. So use 1 extension first, drop in the hole, then add another extension.
http://GPZninja.blogspot.com/
Went to the local dealer today. they had 2 different plug spanners. A short one which was around 10cms and the one I bought which is around 25 cms.. Will try it out on the weekend
- Smitty
Re: re: Plug Spanner L3 ZXR750
hmmmmmBionic wrote:Went to the local dealer today. they had 2 different plug spanners. A short one which was around 10cms and the one I bought which is around 25 cms.. Will try it out on the weekend
the one I got (long time ago)from BKwaka is about 8'(200mm) long
..is perfect
