gear selecting issues
captain slow
Bike: ZXR750
Post by captain slow »
would there be anyone here at ksrc that has any experience with the zxr 750 h1 .i cant get from first to second if motor isnt been reved hard ,with the revs up around 7000 and over the gear box works fine but once you labour the motor around 4000 revs it wont let me go from first to second ,so if any one can enlighten me it would be a big help cheers troy
loubre
State: Northern Territory
Re: gear selecting issues
Post by loubre »
Don't know about the ZXR7fiddys but my ZR7 needs a firm touch, try to be gentle and she won't play the game, the ZX6R though prefers lots of revs to get nice smooth changes, anything over 9000 changes are smooth as silk and just slide through with a very light touch but at lower revs she changes ok but is very clunky and needs a really firm lift!
2005 BMW R1200RT
2012 ZX6R
captain slow
Bike: ZXR750
thanks loubre i have been gentle i have rough to the point near breakng the lever off so i have changed oil scuffed plates changed linkage length so time to book trackday to see if fixed seems to work on the stands in shed cheers troy
You might need to bleed your hydraulic clutch mate - these bikes have a bit of an achilles heel with the clutch actuating system. It might feel like it works properly from the clutch lever ..........but if you have a look at the slave cylinder it may not be moving much at all. This results in exactly the problem you are experiencing - hard shifting.
It might not be the answer to your problem but it is worth checking out anyway just to cross it off the list of possible sources of the problem ?
captain slow
Bike: ZXR750
thanks i will try that to, nice work by the way on all that i have seen come out of the fourth cheers troy
cheers mate :kuda: one day the 4th may get relocated to Newie - its my home town ...
Gosling1 wrote:cheers mate :kuda: one day the 4th may get relocated to Newie - its my home town ...
You would need to move to an industrial estate :shock:
How you gonna pick up the new slabs to get the "house mover" in to move the thing though :lol:
:lol: :lol: NFI mate - I often look in there and say...."what have I done ?..." :shock:
When we moved into this place - it took 14 trips with a LWB Hi-Ace van and my trailer - to move everything I had in the other shed over here.
The amount of *stuff* in there has probably doubled since then. It would be a hell of a move .......
plenty of industrial estates around Newie :lol: :kuda:
