Rusty Fuel tank remedies
- Bike: ZX7R
- State: Western Australia
Hey guys, whats the best way to clean inside a fueltank, its a 1996 zx7r
- Possum
Re: Rusty Fuel tank remedies
Depends on how much rust there is, if there is heaps i wouldnt bother.
Make sure its dry
Put in a few 12mm bolts or nuts in to loosen up (like a scourer)
Use a small ended long handled brush to help lift flakey rust
Dont push too hard on the bolts because you can dint the tank from the inside out and dont forget to count them before putting them in
Get some Industrial molasses (eats rust)
Mix at 1:5 ratio and leave it 3 to 4 days
Empty.
Then when there is NO moisture use a fuel tank sealer.
Its a rubberised compund can pick up for about $100
http://www.kbs-coatings.com.au/kbs-tank-sealers
Make sure its dry
Empty.
or you can use por - 15 which most restorers swear buy,last cost was about $75.00 for the kit
http://www.por15.com/
- ducati_paul
I can vouch for POR15 did a great job on my ZZR tank
If there are no holes, clean with nuts etc then treat with phosphoric acid. No liner required. Done this to 4 or 5 tanks and all worked well. One of my GN250s I did 7 years ago and it is still AOK.
Yeah I like Kawasakis.
- Bike: ZX7R
thanks for the replys i went and bought a por 15 kit so i will see how that goes
- ducati_paul
Take your time with it and follow the instructions exactly, make sure it's nice and dry before you do the coating
- Possum
and let's know how it turns out
Hey Poss when you say industrial molasses is that the same as the molasses that is the by product from the rum factory that they feed the animals
- Possum
That it ish.b.bear wrote:Hey Poss when you say industrial molasses is that the same as the molasses that is the by product from the rum factory that they feed the animals
well they reckon you are never to old to learn and that i didPossum wrote:That it ish.b.bear wrote:Hey Poss when you say industrial molasses is that the same as the molasses that is the by product from the rum factory that they feed the animals
- Possum
Most welcomeh.b.bear wrote:well they reckon you are never to old to learn and that i didPossum wrote:That it ish.b.bear wrote:Hey Poss when you say industrial molasses is that the same as the molasses that is the by product from the rum factory that they feed the animalsthanks
